36
My OS is Ubuntu 14.04. I am trying to download a a 3.6.x firefox version. I've gotten this one. According to the README, all I have to do is unpack, enter the folder and run ./firefox. However, I get the following error when I do that:
./firefox-bin: error while loading shared libraries: libgtk-x11-2.0.so.0: cannot
open shared object file: No such file or directory.
But when I run locate libgtk-x11, it is installed:
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0
/usr/lib/x86_64-linux-gnu/libgtk-x11-2.0.so.0.2400.23
Does anyone know where ./firefox looks for? My guess is that I have to create a link between folders, I just do not know which.
Edit 1: After installing libgtk2.0-0:i386 and trying to run ./firefox again, the libraries libgobject-2.0 can not be found. I try to install them with sudo apt-get install libglib2.0:i368, but I get:
Reading package lists... Done
Building dependency tree
Note, selecting 'libglib2.0-0-refdbg:i386' for regex 'libglib2.0'
Note, selecting 'libglib2.0-dbg:i386' for regex 'libglib2.0'
Note, selecting 'libglib2.0-0:i386' for regex 'libglib2.0'
Note, selecting 'libglib2.0-dev:i386' for regex 'libglib2.0'
Note, selecting 'libglib2.0-data:i386' for regex 'libglib2.0'
Note, selecting 'libglib2.0-doc:i386' for regex 'libglib2.0'
Note, selecting 'libglib2.0-cil:i386' for regex 'libglib2.0'
Note, selecting 'libglib2.0-0-dbg:i386' for regex 'libglib2.0'
Note, selecting 'libglib2.0-bin:i386' for regex 'libglib2.0'
Note, selecting 'libglib2.0-cil-dev:i386' for regex 'libglib2.0'
Note, selecting 'libglib2.0-tests:i386' for regex 'libglib2.0'
Note, selecting 'libglib2.0-data' instead of 'libglib2.0-data:i386'
Note, selecting 'libglib2.0-doc' instead of 'libglib2.0-doc:i386'
libglib2.0-data is already the newest version.
libglib2.0-doc is already the newest version.
libglib2.0-0:i386 is already the newest version.
libglib2.0-0:i386 set to manually installed.
 libglib2.0-cil:i386 : Depends: cli-common:i386 (>= 0.5.6) but it is not installable
                       Depends: libmono-corlib4.0-cil:i386 (>= 2.10.1) but it is not installable
                       Depends: libmono-system4.0-cil:i386 (>= 2.10.7) but it is not installable
Maybe libglib2 is not the library that contains libgobject?
regina_fallangi
  • 461
Your system is 64-bit, but since you want to run a 32-bit version of Firefox, you need to install the 32-bit version of the library:
sudo apt install libgtk2.0-0:i386
fkraiem
  • 12,813
I was having the same problem. @fkraiem answer made me figure out another possibility that fix my issue.
I was trying to run a app in the wrong architecture. So make sure if you are trying to install the right app for your system a 32 or 64 bits.
gvsrepins
  • 341
