This question focuses on Lubuntu, which comes with openbox included in its latest version (14.04.5). As pointed out in the comments, by configuring the ~/.config/openbox/lubuntu-rc.xml file, you can affect the applications included in the ~/.config/autostart, that are run on startup. The following lines added to the <applications> section will place the lxterminal window on the left half, and the gedit window on the right half.
<!-- Allocate 'lxterminal' in the left half-->
<application name="x-terminal-emulator">
<position>
<x>0</x>
<y>0</y>
</position>
<size>
<width>50%</width>
</size>
<maximized>Vertical</maximized>
</application>
<!-- Allocate 'gedit' in the right half-->
<application name="gedit">
<position>
<x>-0</x>
<y>0</y>
</position>
<size>
<width>50%</width>
</size>
</application>
To learn more follow this link.
Update: Regarding how to make it fit to exactly 50% of the screen, it's been posted in the comments (edited):
lxterminal, like some other terminals, uses characters (in width) and rows for height!
In the rc.xml (keybind section), you can Super+T for
sh -c "wmctrl -xa LXTerminal || lxterminal --geometry=84x44 2>/dev/null"
Then, in the applications section, you write:
<application class="Lxterminal" name="lxterminal">
<position force="yes">
<x>-0</x> <y>0</y>
</position>
<decor>no</decor>
</application>.
But you have to get the values for lxterminal by trial and error for the screen with the particular chosen font type and font size.
