I'm a newbie and I messed up with a server trying to reinstall apache2 and php, I did extensive searches inside this forum and in the interwebs but no solution for similar problems helped me. At the moment my web server downloads files instead of opening the web pages so i'm trying to reinstall apache2.
These are the main error i encounter:
E: Package 'liblua5.2-0' has no installation candidate
with apt-get:
# apt-get install apache2
Reading package lists... Done
Building dependency tree
 apache2 : Depends: apache2-bin (= 2.4.23-5.0+deb.sury.org~precise+2) but it is not going to be installed
with aptitude:
# aptitude install apache2
The following NEW packages will be installed:
  apache2 apache2-bin{ab} apache2-data{a} apache2-utils{a} libapr1{a}
  libaprutil1{a} libaprutil1-dbd-sqlite3{a} libaprutil1-ldap{a} ssl-cert{a}
0 packages upgraded, 9 newly installed, 0 to remove and 0 not upgraded.
Need to get 1697 kB of archives. After unpacking 5691 kB will be used.
 apache2-bin : Depends: liblua5.2-0 which is a virtual package.
The following actions will resolve these dependencies:
     Keep the following packages at their current version:
1)     apache2 [Not Installed]
2)     apache2-bin [Not Installed]
Accept this solution? [Y/n/q/?] Y
No packages will be installed, upgraded, or removed.
0 packages upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B of archives. After unpacking 0 B will be used.
I tried to reset the package list with combinations of:
# apt-get update
# apt-get upgrade
# apt-get dist-upgrade
I've also put a clean copy of source.list:
# curl https://repogen.simplylinux.ch/txt/precise/sources_e2fd9ed56e2187914ef4ae006a33c9cc299a8ee8.txt | sudo tee /etc/apt/sources.lis
might be there are package sources listed elsewhere ? I might have added or removed some important but can't remember where.
server operating system:
# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 12.04.5 LTS
Release:    12.04
Codename:   precise
policy:
# apt-cache policy apache2 apache2-bin ssl-cert
apache2:
  Installed: (none)
  Candidate: 2.4.23-5.0+deb.sury.org~precise+2
  Version table:
     2.4.23-5.0+deb.sury.org~precise+2 0
        500 http://ppa.launchpad.net/ondrej/apache2/ubuntu/ precise/main i386 Packages
     2.2.22-1ubuntu1.11 0
        500 http://it.archive.ubuntu.com/ubuntu/ precise-security/main i386 Packages
        500 http://it.archive.ubuntu.com/ubuntu/ precise-updates/main i386 Packages
     2.2.22-1ubuntu1 0
        500 http://it.archive.ubuntu.com/ubuntu/ precise/main i386 Packages
apache2-bin:
  Installed: (none)
  Version table:
ssl-cert:
  Installed: (none)
  Candidate: 1.0.28ubuntu0.1
  Version table:
     1.0.28ubuntu0.1 0
        100 /var/lib/dpkg/status
     1.0.28 0
Any help will be appreciated.
UPDATE:
cat /etc/apt/sources.list
#                            OFFICIAL UBUNTU REPOS                             #
###### Ubuntu Main Repos
deb http://it.archive.ubuntu.com/ubuntu/ precise main
deb-src http://it.archive.ubuntu.com/ubuntu/ precise main
###### Ubuntu Update Repos
deb http://it.archive.ubuntu.com/ubuntu/ precise-security main
deb http://it.archive.ubuntu.com/ubuntu/ precise-updates main
deb-src http://it.archive.ubuntu.com/ubuntu/ precise-security main
deb-src http://it.archive.ubuntu.com/ubuntu/ precise-updates main
cat /etc/apt/sources.list.d/*
deb http://ppa.launchpad.net/boost-latest/ppa/ubuntu precise main
deb-src http://ppa.launchpad.net/boost-latest/ppa/ubuntu precise main
deb https://deb.nodesource.com/node precise main
deb-src https://deb.nodesource.com/node precise main
deb http://ppa.launchpad.net/ondrej/apache2/ubuntu precise main
deb-src http://ppa.launchpad.net/ondrej/apache2/ubuntu precise main
# deb http://ppa.launchpad.net/ondrej/php5-5.6/ubuntu precise main
# deb-src http://ppa.launchpad.net/ondrej/php5-5.6/ubuntu precise main
deb http://ppa.launchpad.net/ondrej/php/ubuntu precise main
deb-src http://ppa.launchpad.net/ondrej/php/ubuntu precise main
deb http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu precise main
deb-src http://ppa.launchpad.net/ubuntu-toolchain-r/test/ubuntu precise main
apt-get -o Debug::pkgProblemResolver=yes install apache2
Starting
Starting 2
Investigating (0) apache2 [ i386 ] < none -> 2.4.23-5.0+deb.sury.org~precise+2 > ( web )
Broken apache2:i386 Depends on apache2-bin [ i386 ] < none -> 2.4.23-5.0+deb.sury.org~precise+2 > ( httpd ) (= 2.4.23-5.0+deb.sury.org~precise+2)
  Considering apache2-bin:i386 1 as a solution to apache2:i386 9999
    Reinst Failed early because of liblua5.2-0:i386
Done
apt-get check
sudo dpkg -C
this outputs nothing
Riccardo
  • 213
