When I open Startup Disk Creator, I see that only there is only 8kB of free space in my USB drive even though I deleted everything in it. When I click on Erase Disk, I then get this error
org.freedesktop.DBus.Python.GLib.Error: Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/dbus/service.py", line 707, in _message_cb
retval = candidate_method(self, *args, **keywords)
File "/usr/share/usb-creator/usb-creator-helper", line 274, in Format
part.call_set_flags_sync(boot_dos_flag, no_options, None)
GLib.Error: udisks-error-quark: GDBus.Error:org.freedesktop.UDisks2.Error.Failed: Error setting partition flags on /dev/sdb2: Command-line `parted --script "/dev/sdb" "set 2 boot off"' exited with non-zero exit status 1: Warning: The driver descriptor says the physical block size is 2048 bytes, but Linux says it is 512 bytes.
(0)
I then attempted to restore the disk image as explained here: Unknown ERROR from Startup Disk Creator
I then entered this in the prompt: dd if=/dev/zero of=/dev/sdb. I then re-tried the Startup Disk Creator and restoring the disk image, but I still get errors
When I try gparted, it gives this warning as soon as it opens:
When I then right-click on the partition and click new, it says
No partition table found on device /dev/sdb
A partition table is required before partitions can be added.
To create a new partition table choose the menu item:
Device --> Create Partition Table.
EDIT: If I click ignore, I see 4 partitions:
/dev/sdb1, File System: unknown, label: Ubuntu-Server
unallocated, File System: unallocated
/dev/sdb2, File System: fat16, Mount Point: /media/Ubuntu-Server
How do I fix this?
