So I have installed Ubuntu to a 1 TB hard drive.(I have a laptop) I want to install Windows 7 to another 500 Gb hard drive and be able to switch out between the two hard drives. Is this possible? Will this cause a fuss with GRUB / Windows bootloader? Does having only one HDD slot in my laptop affect this? Help appreciated.
EpicCode
  • 23
Install the other hard drive and install Windows like you normally would. Then you can swap them with no issue.
One thing you might see is the internal system clock will be incorrect when you go back to Windows, because Linux uses GMT while Windows uses your local time zone. Windows can auto update the clock when its online but it's something you will have to look out for. Here is a registry edit you can do in Windows to fix this.
wjandrea
  • 14,504
Klyn
  • 3,381
