My Ubuntu 14.04 is stuck when trying to login my desktop. The screen goes black and soon after that the login screen comes back.
I've tried ubuntu 14.04 login loop problem and Ubuntu gets stuck in a login loop
But they didn't work. Then I cat .xsession-errors.
It show me following message.
Xlib: extension "GLX" missing on display ":0".
Script for ibus started at run_im.
Script for auto started at run_im.
Script for default started at run_im.
init: at-spi2-registryd main process ended, respawning
init: gnome-session (Unity) main process (26961) terminate with status 1
init: unity-setting-daemon main process (26949) killed by TERM signal
init: update-notifier-crash (/var/crash/_usr_bin_unity-tweak-tool.1000.crash) main preocess (26870) killed by TERM signal
init: update-notifier-crash (/var/crash/_usr_lib_ibus_ibus-ui-gtk3.1000.crash) main preocess (26873) killed by TERM signal
init: xsession-init main process (26939) killed by TERM signal
init: update-notifier-release main process (26890) killed by TERM signal
init: hub main process (26953) killed by TERM signal
init: Disconnected from notified D-Bus bus
init: indicator-bluetooth main process (27025) killed by TERM signal
init: indicator-printers main process (27037) killed by TERM signal
How can I fix it?
