First to start out, I'm very new to Linux, I can get around a little, but beyond that, I rely on forums and posts to get what I need done. Having said that, I've been attempting to install Linux in some form on my older PC for a week now to no avail. I got Debian stable on there and running, but it was hit or miss with the loading, and then I found I couldn't do what I wanted with it, so I moved to Ubuntu Server, didn't work, got frustrated and am now trying Ubuntu desktop. I've gotten errors from the 'HD0' to need to load kernal first, to nothing but blank screens. I've attempted multiple reinstalls, and have tried boot-repair. I don't know what I am doing and why this won't work.
This is the pastebin from the boot repair: http://paste.ubuntu.com/23297489/
This is attempting to install only Ubuntu on the HDD, no other OS.
System info:
CPU: AMD Phenom II x4 995 3.2 GHz
16gb RAM
80GB SDD
CDROM
Unsure of Legacy/UEFI modes, my CMOS setup does not allow me to change that.
Let me know if you guys need anymore info, or wish to help me with this.
Thanks in advance.
It is definitely an install in legacy-mode and checking the boot-info-summary the install looks clean. The problem seems to be with your graphics-card Radeon HD 5770. To boot to Ubuntu do the following:
  1. Immediately after the BIOS splash screen during boot, press and hold the SHIFT button. This will display you grub containing a list of kernels and recovery option
  2. Select the first kernel and presse to edit boot options
  3. Find the line ending with quiet splash. Add the nomode- option before these key words - i.e. so the line looks like [...]nomodeset quiet splash
  4. Press CTRL + X to boot
Look for detailed information for this steps in this answer.
Open the dash and type "drivers", click on the Additional Drivers-icon and check if Ubuntu give you any options to install an appropriate driver for the graphics card. See detailed information for this step here.
A driver for your graphics card is available, but it seems to use it you will have to use Ubuntu 14.04. Look for detailed information and how to install this driver here.
mook765
  • 18,644
I ended up just reinstalling over and over again, and eventually got it to load in and was able to see everything and perform updates. Thanks for the help guys.
