In order to pass a password in a shell script you will have to write:
sudo mount -t cifs -o password=asdasd,username=mc007,uid=1000 //192.168.1.105/cfmaster/ /PMaster/projects/x4mm/win
But there are situations you don't want to use sudo (build-scripts,...).
And so if you don't use sudo, the command will abort with:
only root can use "--options" option
Now, how can one mount network share with password from within a non-interrupting shell script?
thanks
edwinksl
  • 24,109
xamiro
  • 563
As mentioned in the comments, user 'muru' suggests to look at How do I run specific sudo commands without a password?. After researching it seems the only official supported way to mount a password protected windows share from within a script.
It needs you to be a tech savy, and it needs you to alter system files with root permissions.
xamiro
  • 563
