I'd like to create a tar file to compress a folder that contains sub folders. I'm trying with the following command int in the terminal:
tar -czf folder directorios.tar.gz
directorios.tar.gz would be the result
Try:
tar -czvf directorios.tar.gz folder
A few notes:
Recursion is the default, from the tar man pages:
-c, --create
Create a new archive. Arguments supply the names of the files to be archived.
Directories are archived recursively, unless the --no-recursion option is
given.
Although this can be turned off by using the --no-recursion option...
You need the archive name immediately after the -f option, the correct sequence being:
tar -c [-f ARCHIVE] [OPTIONS] [FILE...]
For a more flexible command line (particularly if you wanted to use other compression utilities apart from gzip with tar) you could omit the -z option and use -a or --auto-compress option to allow tar to automatically decide which compressor to use based on the archive suffix:
-a, --auto-compress
Use archive suffix to determine the compression program.
Recognised suffixes (and their attendant compressing applications) are:
tar is pretty cool :)
References:
