A few days ago, while I was doing some network configuration tests, I went offline.
At first I did not realize, but all indicators (cpu, memory, ...) even the one of the network manager disappeared from the top panel...
Using a USB live, I reinstalled network-manager, but I'm still unable to see the icon.
The indicators are also running, but they're not visible (same as the network manager).
How can I get them back visible in the top panel?
Zanna
  • 72,312
I find the network indicator sometimes disappears in 16.04 with unity after restarting network-manager (systemctl restart NetworkManager) as above. What seems to be happening is that the nm-applet is crashing
Try running (using alt-f2, terminal would work too but then you have to remember not to close that terminal)
nm-applet
Sometimes you may also need to restart the unity panel as per this question
https://askubuntu.com/questions/46788/is-it-possible-to-restart-the-unity-panel-without-restarting-compiz
NeilenMarais
  • 1,038
  • 17
I've had the same problem with Ubuntu 16.04; it happens occasionally or when resuming from suspend. A fix that worked for me is to open the terminal and type:
This fixes it immediately.
Zanna
  • 72,312
There is an open bug with the Wifi indictor icon disappearing in Ubuntu 16.04 since May 2016.
https://bugs.launchpad.net/ubuntu/+source/indicator-applet/+bug/1585886
AnthonyWC
  • 224
