How prevent LXDE to start at boot.
I prefer to start ubuntu server 16.04 without LXDE running so it coms with the command prompt afther boot. Start LXDE with the command startx. So how can i prevent that LXDE is started at boot time.
Tanks, Ian
As far as I could see with a quick look at apt, lxde should be using lxdm instead of lightdm. If this is the case - AND lxdm is started through the systemd service "lxdm", the following command will disable it during startup:
systemctl disable lxdm.service
In case I am wrong with all these assumptions (I don't use lxde, so I pretty well might be), try to disable the lightdm service, which might in this case be a wrapper that starts whatever is configured somewhere else:
systemctl disable lightdm.service
does this solve your issue?
