I'm trying to install steam on my new pc but it just won't run.
Running Steam on ubuntu 14.04 64-bit
STEAM_RUNTIME is enabled automatically
Installing breakpad exception handler for appid(steam)/version(0)
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: swrast
I've tried some solutions I've find on the Internet (like Problem with installing Steam on Ubuntu 15.04+ or Steam won't open in Ubuntu 15.10). Most of them seem to say that it's a problem with steam trying us old libraries and that some files should be removed.
I've tried it and it still doesn't work. Here is the content of the folder ~/.steam/steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-linux-gnu/
libfreetype.so.6        libXau.so.6.0.0    libXinerama.so.1
libfreetype.so.6.8.0    libxcb.so.1        libXinerama.so.1.0.0
libstdc++.so.6.0.18     libxcb.so.1.1.0    libXrandr.so.2
libstdc++.so.6.disable  libXdmcp.so.6      libXrandr.so.2.2.0
libX11.so.6             libXdmcp.so.6.0.0  libXrender.so.1
libX11.so.6.3.0         libXext.so.6       libXrender.so.1.3.0
libXau.so.6             libXext.so.6.4.0
As you can see, I've tried renaming libstdc++.so.6 because it worked for some people out there and I've also removed libgcc_s.so.1 in ~/.steam/steam/ubuntu12_32/steam-runtime/i386/lib/i386-linux-gnu/ but the problem remains.
I have a GTX 1070 and I manually installed NVIDIA-Linux-x86_64-367.27.run from the nvidia website (I don't know if that matters)
I'm starting to feel desperate. How good is a gaming pc if you can't run steam :'( Anyone has any solution ? I don't want to have to go back to windows ><
Columini
Ok I removed steam and then used
sudo apt-get install steam-launcher
instead of
It downloaded an update and now when I run steam it tells me
Steam needs to install these additional packages:
    libgl1-mesa-dri:i386, libgl1-mesa-glx:i386
and asks for my password. Then
Reading package lists... Done
Building dependency tree
 libgl1-mesa-glx:i386 : Depends: libglapi-mesa:i386 (= 10.1.3-0ubuntu0.6)
 unity-control-center : Depends: libcheese-gtk23 (>= 3.4.0) but it is not going to be installed
                        Depends: libcheese7 (>= 3.0.1) but it is not going to be installed
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
Press return to continue:
And then when I press return, a windows shows up saying
You are missing the following 32-bit libraries, and Steam may not run:
libGL.so.1
libstdc++.so.6
libstdc++.so.6
libstdc++.so.6
libstdc++.so.6
libstdc++.so.6
libstdc++.so.6
libstdc++.so.6
Then I click "ok" and terminal shows
/home/user/.local/share/Steam/ubuntu12_32/steam: error while loading shared libraries: libstdc++.so.6: wrong ELF class: ELFCLASS64
/home/user/.local/share/Steam/steam.sh: line 444: no match: ssfn*
user@user-desktop:~/.steam/steam/ubuntu12_32/steam-runtime/i386/usr/lib/i386-lin
Columini
Ok I managed to make it work :D
I basically reinstalled ubuntu and instead of gettind nvidia's drivers from their website I did it from the repository
sudo apt-get install linux-source
sudo add-apt-repository ppa:graphics-drivers/ppa
sudo apt-get update
sudo apt-get install nvidia-367
Columini
