I'm trying to enable the middle click with 3 fingers on my touchpad usingsynclient ClickFinger3=2. I know from similar questions that the modification is not permanent after standby, so I used the workaround provided in the first answer of this question in order to avoid this problem.
But the problem is that when I turn on the computer, the middle button click does not work and only when resuming from standby it starts to work perfectly.
I check the output of synclient right after the startup and the setting ClickFinger3=2 is already there. So the option is already set but it starts to work after a resume from standby.
Asked
Active
Viewed 138 times
