I have gone into compizconfig's grid section and customized all the tiling commands.
When I was testing the commands, I didn't see that any of them effectively centered the screen.
I went into the window placement section and configured new windows to open centered. But if I move a window to the right side and then want to center it, I don't know how I should do that with a keyboard command. The "put center" will maximize it and "restore" will move it to its most recent position / size.
To summarize
say I have a window covering the right half of the screen. I want to keep the dimensions / size the same, but just center it.
max pleaner
  • 1,140
Introduction:
The following script aligns the center of the user's active window with screen's center. It is intended to be bound to a keyboard shortcut in Settings -> Keyboard ->Shortcuts menu.
Usage:
  1. Save the script as ~/bin/center_active_window.py. Ensure it has executable permissions with chmod +x ~/bin/center_active_window.py
  2. Open System Settings -> Keyboard -> Shortcuts -> Custom. Click +.
  3. You will be prompted with a popup asking for Name and Command. Name can be anything, command has to be full path to your new script, i.e. /home/your_user_name/bin/center_active_window.py. Click Apply
  4. Click on the Disabled text and assign it a custom keybinding once prompted. I'm using Ctrl+Super+C , but you can use whatever you like.
Source code
Also available as gist on GitHub
#!/usr/bin/env python3
# Author: Serg Kolo
# Date: Oct 3rd, 2016
# Description: Script for aligning the center of
#     user's active window with the center of the monitor
# Tested on: Ubuntu 16.04
# Written for: http://askubuntu.com/q/832720/295286
from __future__ import print_function
from gi.repository import Gdk
import subprocess
def get_offset(*args):
    command = ['xprop','-notype','_NET_FRAME_EXTENTS',
               '-id',str(args[0])
    out = subprocess.check_output(command)
    return int(out.decode().strip().split(',')[-2])
def main():
    screen = Gdk.Screen.get_default()
    window = screen.get_active_window()
    window.unmaximize()
    window_width = window.get_width()
    window_y = window.get_origin()[-1]
    print(window_y)
    window_monitor = screen.get_monitor_at_window(window)
    monitor_center = screen.get_monitor_geometry(window_monitor).width/2
    # if centers of window and screen are aligned
    # the top left corner will be at screen_center - window_width/2
    new_position = monitor_center - window_width /2
    # For some reason there is vertical offset necessary
    # Apparently this comes form _NET_FRAME_EXTENTS value
    offset = get_offset(int(window.get_xid()))
    window.move(new_position,window_y-offset)
    print(window.get_origin())
if __name__ == '__main__':
    main()
guys. I know this is an old question, but I've been searching for the same thing and, after a lot of testing, I came up with my own script and, if you don't mind, I'd really like to share it with you.
#!/bin/sh
ScreenX=$(xdpyinfo | awk -F'[ x]+' '/dimensions:/{print $3}') ScreenY=$(xdpyinfo | awk -F'[ x]+' '/dimensions:/{print $4}')
WindowX=$(xwininfo -id $(xdotool getactivewindow) | awk -F'[ :]+' '/Width:/{print $3}') WindowY=$(xwininfo -id $(xdotool getactivewindow) | awk -F'[ :]+' '/Height:/{print $3}')
#WindowX=$(xwininfo -id $(xdotool getactivewindow) | sed -n -e "s/^ +Width: ([0-9]+)./\1/p") #WindowY=$(xwininfo -id $(xdotool getactivewindow) | sed -n -e "s/^ +Height: ([0-9]+)./\1/p")
PositionX=$(((ScreenX/2)-(WindowX/2))) PositionY=$(((ScreenY/2)-(WindowY/2)))
#echo "Screen X: " $ScreenX #echo "Window X: " $WindowX #echo "Position X: " $PositionX
#echo "Screen Y: " $ScreenY #echo "Window Y: " $WindowY #echo "Position Y: " $PositionY
wmctrl -r :ACTIVE: -e 1,$PositionX,$PositionY,$WindowX,$WindowY
Some commands are commented. I decided to keep them just for curiosity purposes because they worked very well while I was trying to figure out what to do (I'm not very familiar with bash scripts).
If anyone knows how to make this script cleaner and/or smoother, feel free to enlighten us. That'd be very cool.
I hope it's useful.
Cheers.
brunces
  • 659
  • 17
It's possible to specify the shortcut via GSettings:
gsettings set org.gnome.desktop.wm.keybindings move-to-center "['<Control><Alt>J']"
The same could be done via GUI by installing dconf-editor (dconf is the system backing GSettings).
Credits: /u/carmanaughty.
raindev
  • 101
