11
Hi I have installed MariaDB server and mariaDB client, php7.0-mysql on my fresh Ubuntu 16.04 VPS, but after installation I cant login using PhpMyAdmin, when I am trying to login using PHPMyAdmin its always give Access denied for user 'root'@'localhost' error.
here is some info. If try to get status
root@ubuntu-2gb-ams2-01:/var/lib# service mariadb status
● mariadb.service
   Loaded: not-found (Reason: No such file or directory)
   Active: inactive (dead)
When I tried to start get this
# service mariadb start
Failed to start mariadb.service: Unit mariadb.service not found.
I can login and create new database with SSH
root@ubuntu-2gb-ams2-01:/var/lib# mysql -u root -p
Enter password:
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MariaDB connection id is 61
Server version: 10.0.27-MariaDB-0ubuntu0.16.04.1 Ubuntu 16.04
Copyright (c) 2000, 2016, Oracle, MariaDB Corporation Ab and others.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
MariaDB [(none)]> create database protest;
Query OK, 1 row affected (0.00 sec)
If I want to see database then I can see all database
root@ubuntu-2gb-ams2-01:/var/lib# mysql -u root -p -e 'show databases'
Enter password:
| Database           |
| information_schema |
| mysql              |
| performance_schema |
| protest            |
So its look like Mariadb is installed but cant understand why status showing dead, start/restart not working, front end login not working (using phpmyadmin, can anyone give a clue?
UPDATE: I just created another DB and user, I can login that user and access db using phpmyadmin.
Mi2
  • 113
If you check mysql --version it should say something like:
mysql  Ver 15.1 Distrib 10.1.16-MariaDB, for debian-linux-gnu (x86_64) using readline 5.2
Then you know you're indeed running mariaDB then you can simply
sudo service mysql restart
and it should be all good!
Worth to lookup the file in /lib/systemd/system/mariadb.service to see that it uses mysqld.
pomsky
  • 70,557
Jan Myszkier
  • 1,273
MariaDB is running, it's just that it has disguised itself as MySQL (sneaky). MariaDB is a drop-in replacement for MySQL, so you start the MariaDB monitor using the CLI $ mysql command, etc. All interactions where you specify MySQL directly in some way will actually affect MariaDB. (I don't know what happens if you are also running MySQL!) So to run MariaDB, the command is
$ service mysql start
Again, try this
$ service mysql status
to generate a whole lot of info, including something like this:
16 08:19:55 <YR-CMPTR> mysqld[1769]: Version: '10.0.28-MariaDB-0ubuntu0.16.04.1'  socket: '/var/run/mysqld/mysqld.sock'  port: 3306
All apps that normally use MySQL won't even notice that they are interacting with MariaDB.
I believe the status thing is still using MySQL's name for the MariaDB package. Try
This should give you an "active (running)" status.
After migrating from MySQL to MariaDB, I had issues logging in as root from my (development) Chamilo portal (an e-learning platform) in PHP (so connecting through TCP/IP). I could, however, perfectly connect from the command line.
Checking mysql.user, I found that the "plugin" column said "unix_socket". This is all due to the new management of authentication through plugins since MySQL 5.5 and MariaDB 5.2.
I fixed it by re-granting all privileges to root without any plugin mention:
grant all privileges on *.* to root@'127.0.0.1' identified by 'mypass';
flush privileges;
This simply emptied the "plugin" column and I could connect through TCP/IP again.
ywarnier
  • 461
