When I follow that advices: TeamViewer 11 won't run on Ubuntu 16.04 64-bit I get following errors:
al@alpc:~/Downloads$ sudo dpkg -i teamviewer_11.0.57095_i386.deb
Selecting previously unselected package teamviewer:i386.
(Reading database ... 286983 files and directories currently installed.)
Preparing to unpack teamviewer_11.0.57095_i386.deb ...
Unpacking teamviewer:i386 (11.0.57095) ...
dpkg: dependency problems prevent configuration of teamviewer:i386:
teamviewer:i386 depends on libdbus-1-3.
teamviewer:i386 depends on libfontconfig1.
teamviewer:i386 depends on libsm6.
But when I try to install missed libs I see:
al@alpc:~/Downloads$ sudo apt-get install libdbus-1-3 libdbus-1-3:i386
Reading package lists... Done
Building dependency tree
libdbus-1-3 is already the newest version (1.10.6-1ubuntu3).
You might want to run 'apt-get -f install' to correct these:
libdbus-1-3:i386 : Depends: libsystemd0:i386 but it is not going to be installed
teamviewer:i386 : Depends: libfontconfig1:i386 but it is not going to be installed
Depends: libsm6:i386 but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
And so on for all required libs. Trying to fix dependencies didn't helps me:
al@alpc:~/Downloads$ sudo apt-get -f install
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
appstream dns-root-data dnsmasq-base ethtool gdbserver gnome-software gnome-software-common iputils-arping libappstream3 libasound2:i386 libbabeltrace1 libc6-dbg libfreetype6:i386
libgpg-error0:i386 libgtkspell3-3-0 libice6:i386 liblzma5:i386 libmbim-glib4 libmbim-proxy libmm-glib0 libndp0 libnetfilter-conntrack3 libpng12-0:i386 libqmi-glib1 libqmi-proxy libx86-1
linux-headers-4.4.0-31 linux-headers-4.4.0-31-generic linux-image-4.4.0-31-generic linux-image-extra-4.4.0-31-generic linux-signed-image-4.4.0-31-generic mobile-broadband-provider-info
modemmanager plainbox-secure-policy pm-utils procmail pyotherside python-kerberos python3-checkbox-support python3-guacamole python3-jinja2 python3-padme python3-plainbox python3-pyparsing
python3-xlsxwriter qml-module-io-thp-pyotherside qmlscene qtdeclarative5-dev-tools sensible-mda usb-modeswitch usb-modeswitch-data vbetool
Use 'sudo apt autoremove' to remove them.
The following packages will be REMOVED:
teamviewer:i386
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
After this operation, 194 MB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
When I try to run teamviewer:
al@alpc:~/Downloads$ teamviewer
Init...
XRandRWait: No value set. Using default.
XRandRWait: Started by user.
Checking setup...
err:ole:CoGetClassObject class {4315d437-5b8c-11d0-bd3b-00a0c911ce86} not registered
err:ole:CoGetClassObject no class object {4315d437-5b8c-11d0-bd3b-00a0c911ce86} could be created for context 0x3
wine: configuration in '/home/al/.local/share/teamviewer11' has been updated.
Launching TeamViewer ...
Starting network process (no daemon)
/opt/teamviewer/tv_bin/teamviewerd: error while loading shared libraries: libdbus-1.so.3: cannot open shared object file: No such file or directory
Network process already started (or error)
Launching TeamViewer GUI ...
About libdbus it seems that this library is installed:
al@alpc:~/Downloads$ sudo find / -iregex ".*libdbus-1.so.3.*"
/lib/x86_64-linux-gnu/libdbus-1.so.3
/lib/x86_64-linux-gnu/libdbus-1.so.3.14.6
How to fix that? What is the problem. I completely confused.
