Im running 64 bits version, Im very new to ubuntu, just dived into it. this is what I do:
wget https://dl.google.com/linux/direct/google-chrome-stable_current_amd64.deb
then get:
`2016-10-01 23:22:41 (1.30 MB/s) - ‘google-chrome-stable_current_amd64.deb’ saved [49990192/49990192]`
then
sudo dpkg –I google-chrome-stable_current_amd64.deb
and get:
dpkg: error: need an action option
Type
dpkg --help for help about installing and deinstalling packages [*];
Use 'apt' or 'aptitude' for user-friendly package management;
Type
dpkg -Dhelp for a list of dpkg debug flag values;
Type
dpkg --force-help for a list of forcing options;
Type
dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through 'less' or 'more' ! Thanks in advance and sorry for my idiocy too
L. D. James
  • 25,444
Ben
  • 43
You typed the wrong command to install the application. You used an uppercase I when it should have been a lower case i. Unlike Windows, the case of the letters in a command makes a difference.
Run this to install the package:
$ sudo dpkg -i google-chrome-stable_current_amd64.deb
Just change your Uppercase I to the lowercase i in the command you typed and you'll be all set.
By the way, the difference between the lower case and the uppercase i is:
-i (lowercase) Install the package
-I (uppercase) Show information about the package.
For other details see:
$ man dpkg
edwinksl
  • 24,109
L. D. James
  • 25,444
-1
In Ubuntu Xenial (16.04) you can simply install with apt:
sudo apt install google-chrome-stable_current_amd64.deb
David Foerster
  • 36,890
  • 56
  • 97
  • 151
Alex
  • 485
