Regardless of battery charge, when unplugged Ubuntu displays critical battery message and hibernates. I can only seem to change it to either shutdown or hibernate.
This does not happen when using windows 7 on the same computer. Windows 7 gives a good few hours on a full charge indicating that it is not a battery problem.
Any help? I really don't want to have to use windows but its kinda pointless having a netbook that doesn't work when not plugged in!
I'm using a toshiba nb250 and the most up to date 11.10 ubuntu distro. I use to get the critical battery message before on the previous ubuntu but it never shut down or hibernated my computer.
Chesc
  • 61
I guess your computer is configured to suspend/shutdown when he thinks the battery level is critical. To change that behaviour, you need to install dconf-tools. Then open it in dash (dconf Editor), and follow this path:
 org > gnome > settings-daemon > plugins > power
And change the value of critical-battery-action to nothing. Also, if the battery is marked as broken, you can also uncheck the option notify-perhaps-recall.
Hope it helps.
Salem
  • 19,864
  • 65
  • 90
If you want to keep the action (IE: Hibernate) open dconf-editor: org > gnome > settings-daemon > plugins > power and just uncheck: use-time-for-policy, this will force the OS to use the percentage base instead of the ACPI Bios.
Adonis
