Here is one question that encountered during the make process of
gcc4.6.2
as I tried to type the make -j16 , there showed the following error messages:
I tried to search the web site by google and found that it might due to gcc version which will be compiled with older version so that it did not exist the CXXABI_1.3.8.I also tried to search the directory that the error message mentioned, that is /usr/lib/x86_64-linux-gnu/libiccu.so.55 which is exist in my directory and I also tried to use LIBRARY_PATH =/usr/lib/x86_64-linux-gnu$LIBRARY_PATH and export LIBRARY_PATH then remake the gcc. but it still show the following message. I do not know exactly how to fix this problem ? How to get a newer version of libstdc++ ?
Thanks you!
PS: My os is Ubuntu16.04 LTS 64 bit.
/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/lib/x86_64-linux-gnu/libicuuc.so.55)
make[4]: *** [de.mo] Error 1
make[4]: *** Waiting for unfinished jobs....
msgfmt: /home/paultsai/gcc/x86_64-linux-gnu/libstdc++-v3/src/.libs/libstdc++.so.6: version `CXXABI_1.3.8' not found (required by /usr/lib/x86_64-linux-gnu/libicuuc.so.55)
make[4]: *** [fr.mo] Error 1
make[4]: Leaving directory `/home/paultsai/gcc/x86_64-linux-gnu/libstdc++-v3/po'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/paultsai/gcc/x86_64-linux-gnu/libstdc++-v3'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home/paultsai/gcc/x86_64-linux-gnu/libstdc++-v3'
make[1]: *** [all-target-libstdc++-v3] Error 2
make[1]: *** Waiting for unfinished jobs....
config.status: executing libtool commands
config.status: executing gstdint.h commands
make[1]: Leaving directory `/home/paultsai/gcc'
make: *** [all] Error 2
PaulTsai
  • 115
