-2
How can I view all the available wifi networks around me?
At top right corner of your system you can see a signal symbol. Click on that and tick the Enable Wi-Fi.It will show all available Wi-Fi networks.
I've seen many occasions where, for some reason, NetworkManager's GUI doesn't show all the available networks. In fact at times it doesn't even list Wireless as a choice. On those occasions I use the cli option to scan:
$ nmcli -f in-use,ssid,bssid,signal,bars  dev wifi
*  SSID               BSSID              SIGNAL  BARS
   Apollo III (TWC)   xx:xx:xx:xx:xx:xx  100     ▂▄▆█
   Chromecast8481     xx:xx:xx:xx:xx:xx  100     ▂▄▆█
   TWCWiFi-Passpoint  xx:xx:xx:xx:xx:xx  90      ▂▄▆█
   Apollo III (1)     xx:xx:xx:xx:xx:xx  90      ▂▄▆█
   CableWiFi          xx:xx:xx:xx:xx:xx  87      ▂▄▆█
   TWCWiFi            xx:xx:xx:xx:xx:xx  87      ▂▄▆█
*  Apollo III (1)     xx:xx:xx:xx:xx:xx  70      ▂▄▆_
   ZJG8Q              xx:xx:xx:xx:xx:xx  47      ▂▄__
For security reason I X'ed out the mac addresses.
If I have connected to the network before I can use this cli to connect again:
$ nmcli c up "Apollo III (1)"
If I'm connecting for the first time I'll use this command:
$ nmcli d wifi connect "Apollo III (1)"
A GUI prompt will come up with the option to type in the code works the terminal screen will respond with successful activation and I'll be connected.
I also tested to verified that the elevated sudo command isn't required for any of the commands above.
L. D. James
  • 25,444
