78
The headline basically says it all. I have a program where I am only given the PID, nothing more really, and I would like to know how I get more information about the given process.
Philip
  • 783
ps -Flww -p THE_PID
will show you some information. See the ps manpage for more information about the ps command. The "STANDARD FORMAT SPECIFIERS" section explains what the different columns mean.
26
I don't know what is your exact requirement. but this may help you.
There is separate directory for every process with name as pid number in /proc .
ps -ef | grep docker
root      1700     1  0 Sep20 ?        00:03:04 /usr/bin/docker daemon --raw-logs
In above output PID is 1700 .
goto /proc/1700
cd /proc/1700
and do ls there
ls
attr       clear_refs       cpuset   fd       limits     mem         net        oom_score      projid_map  sessionid  stat     task
autogroup  cmdline          cwd      fdinfo   loginuid   mountinfo   ns         oom_score_adj  root        setgroups  statm    timers
auxv       comm             environ  gid_map  map_files  mounts      numa_maps  pagemap        sched       smaps      status   uid_map
cgroup     coredump_filter  exe      io       maps       mountstats  oom_adj    personality    schedstat   stack      syscall  wchan
there is many file that have all information about process.
Like:
cat /proc/1700/status
State:  S (sleeping)
Tgid:   1700
Ngid:   0
Pid:    1700
PPid:   1
TracerPid:  0
Uid:    0   0   0   0
Gid:    0   0   0   0
FDSize: 64
Groups: 0 999
VmPeak:   527576 kB
VmSize:   527512 kB
VmLck:         0 kB
VmPin:         0 kB
VmHWM:     46032 kB
VmRSS:     34180 kB
VmData:   449308 kB
VmStk:       136 kB
VmExe:     28324 kB
VmLib:      4236 kB
VmPTE:       296 kB
VmSwap:     5324 kB
Threads:    12
SigQ:   0/63662
SigPnd: 0000000000000000
ShdPnd: 0000000000000000
SigBlk: 0000000000000000
SigIgn: 0000000000000000
SigCgt: ffffffffffc1feff
CapInh: 0000000000000000
CapPrm: 0000003fffffffff
CapEff: 0000003fffffffff
CapBnd: 0000003fffffffff
Seccomp:    0
Cpus_allowed:   f
Cpus_allowed_list:  0-3
Mems_allowed:   00000000,00000001
Mems_allowed_list:  0
voluntary_ctxt_switches:    437726
nonvoluntary_ctxt_switches: 27579
If you need basic command to get process information then you can easily get using command:
man ps
pl_rock
  • 11,715
To add to the ps answer there is also the pidstat command which will show additional stats like the time spent in user mode or the occupation of the cpu. You can use it with:
# pidstat -p 51648
You can also add the -d flag to add details about I/O:
# pidstat -p 51648 -d
And you can also an integer as a second parameter to make the command refresh each X seconds:
# pidstat -p 51648 3
statox
  • 161
px, available via the px package, is a great tool for giving detailed information about a running process.
px $SOME_PID
Abdull
  • 734
