I'm trying to control my ubuntu server's fan speed. It has an Asrock 970 extreme4 with an AMD 8350.
I installed fancontrol etc however when I run pwmconfig it outputs:
Found the following devices:
   hwmon0 is nct6776
   hwmon1 is fam15h_power
   hwmon2 is k10temp
Found the following PWM controls:
   hwmon0/pwm1           current value: 255
   hwmon0/pwm2           current value: 255
   hwmon0/pwm3           current value: 255
Giving the fans some time to reach full speed...
Found the following fan sensors:
   hwmon0/fan1_input     current speed: 0 ... skipping!
   hwmon0/fan2_input     current speed: 0 ... skipping!
   hwmon0/fan3_input     current speed: 0 ... skipping!
   hwmon0/fan4_input     current speed: 0 ... skipping!
   hwmon0/fan5_input     current speed: 0 ... skipping!
There are no working fan sensors, all readings are 0.
Make sure you have a 3-wire fan connected.
You may also need to increase the fan divisors.
See doc/fan-divisors for more information.
Meaning I get no fancontrol config file so I'm not exactly sure what is going on.
Not really the best fix ever but I just turned the fan down manually so my server is not loud as all hell.
echo 170 > /sys/class/hwmon/hwmon0/pwm2
