I have installed Ubuntu 11.10 successfully and everything works perfectly except the fan, it is working constantly and it has nothing to do with the CPU because if I don't open any programs it will remain at high speed.
I figured it may be because of AMD/ATI, I tried different ways of installing it manually and even automatically via Ubuntu itself but never worked!
Is there a (basic if possible) way of fixing this? Maybe controlling the fan speed would do the trick.
Jorge Castro
  • 73,717
Nima
  • 131
This is normal functioning for a laptop. Remember that the external temperature of the laptop is not necessarily a guide as to the temperature of the CPU, and naturally manufacturers are cautious when it comes to keeping the hardware cooled!
twister_void
  • 5,934
Just installed Ubuntu 20.04 on this notebook with some upgrades like:
  • now it has 4GB RAM total
  • SSD 240GB
the fan goes up and down, so it looks that Ubuntu manages the fan but in the reality it doesn't go to minimum , neither while idle
When I have installed the SSD, 1 hour ago, I took the occasion to make a deep clean of the fan and the air circuit
I have the HDD with windows 7 and so I'm just testing ubuntu 20. So I have pretty sharp the fan speed when Windows 7 is idle: it is hard to ear the fan
Please read carefully: just installed ubuntu 20 and I'm using Firefox to write in this question
Any idea or hint to make this usable, otherwise it is a pain earing the fan all the time
thank you
Robert
  • 177
Are you using VmWare ? If so you are using more of the RAM then normal, it will take 1GB to run the OS image then if your using Win 7 at lest 2GB will need to be working just to keep that running
So it could be the RAM thats going over drive
david
