How do I install PostgreSQL 9.6 on any Ubuntu version since it doesn't come by default with the most recent version?
Ubuntu Xenial (16.04) comes with PostgreSQL 9.5 from the default repositories.
For the following Ubuntu versions, you can install with the given commands, as per the official PostgreSQL Apt Repository.
Version 9.6 comes with the distribution.
sudo apt-get install postgresql-9.6
sudo add-apt-repository "deb http://apt.postgresql.org/pub/repos/apt/ $(lsb_release -sc)-pgdg main"
wget --quiet -O - https://www.postgresql.org/media/keys/ACCC4CF8.asc | sudo apt-key add -
sudo apt-get update
Follow below steps:
Reference is taken from this blog.
You need to add the latest PostgreSQL repository for the latest version.
sudo add-apt-repository "deb https://apt.postgresql.org/pub/repos/apt/ trusty-pgdg main"
Update and Install PostgreSQL 9.6:
sudo apt-get update
Default postgres super user and postgres database is created. You need to set a password for the postgres super user.
ubuntu@:~$ sudo passwd postgres
Enter new UNIX password:****
Retype new UNIX password:****
passwd: password updated successfully
If service is not started, you can start the PostgreSQL service.
sudo service postgresql start
Connect PostgreSQL server using postgres user:
ubuntu@:~$ su postgres
Password:****
Create a sample database:
createdb database_name
Connect to that database:
psql -d database_name
The accepted answer wouldn't work for me on WSL Ubuntu 18.04.
What did work for me was based on https://medium.com/@philip.mutua/how-to-install-postgresql-9-6-on-ubuntu-16-04-and-14-04-lts-5d463da49ea5
essentially:
sudo sh -c 'echo "deb http://apt.postgresql.org/pub/repos/apt/ `lsb_release -cs`-pgdg main" >> /etc/apt/sources.list.d/pgdg.list'
wget -q https://www.postgresql.org/media/keys/ACCC4CF8.asc -O - | sudo apt-key add -
sudo apt-get update
sudo apt-get install postgresql-9.6 postgresql-contrib-9.6
I simply added -9.6 to the installed packages.
I followed this Github gist - I am running ubuntu xenial inside vagrant and wanted to upgrade existing postresql official repository vesion 9.5 to 9.6 so that I can use PostGIS extension which is served best by version 9.6 (officially mentioned in their site) Hope this helps someone.
