After playing any video...following msg is shown: Required plugin could not be found Videos requires to install plugins to play files of the following types: • MPEG-4 AAC decoder • H.264 (Main Profile) decoder
Asked
Active
Viewed 6,624 times
For this specific type you can install either gstreamer1.0-plugins-bad or gstreamer1.0-libav Both will enable h.264 & aac decoding. Probably best in long run to just install both.
sudo apt install gstreamer1.0-plugins-bad gstreamer1.0-libav
If you wanted to fill out support further you could add the gstreamer1.0-plugins-ugly package though not needed in this case.
doug
- 17,212
