As a last resort to my question, I am yet to try the mem parameter of kernel to force it to use the specified amount of RAM. Short Summary - I can only see 3.2GB RAM on a 64bit OS and am not sure ifs a hardware limitation, so wants to try as I found a post on Ubuntuforums.
My question is if its ok to play with my resident Ubuntu install or should I be using a live bootable usb? What values do I try (I have 6GB with only 3.2GB being usable) and how to keep it safe? I don't want to burn any of my hardware component at this point of time or make the system unbootable.
Running Ubuntu 11.10 with kernel 3.0.0-13-generic
Ashfame
  • 3,304
Weird, that Ubuntuforums link wants a login but I can view random other threads without logging in.
Anyway I'm guessing you're referring to mem=xM in your bootloader. This is perfectly safe to try on your current install. For 6GB you want mem=6144M (6*1024).
Just try tacking it onto the end of the line with the other options, which will include such things as quiet splash ro root=UUID=$stuff.
For safety, I would not recommend you edit any config files to do this the first time. While booting, hold Shift to get into GRUB and then press e to edit the highlighted grub entry. You can move around with the cursor keys to find the line you want to edit; add mem=6144M onto the end and boot (see directions at the bottom of the screen).
If it works, add it to /etc/default/grub in the line GRUB_CMDLINE_LINUX_DEFAULT, and run sudo update-grub.
Caesium
  • 16,207
  • 42
  • 48
