24
I have a headless box that will be used for CUDA computing. I installed Ubuntu server 16.04.1 but when I try to install the nVidia drivers via apt-get it also wants me to install X11 and other GUI components.
How can I just install the driver and CUDA libs without installing X11 and friends?
Ideally without downloading the run file directly from nVidia. I'd like to use debian packages if possible.
Zanna
  • 72,312
en4bz
  • 722
The way to do this on recent versions of Ubuntu:
sudo apt install --no-install-recommends nvidia-cuda-toolkit nvidia-headless-440 nvidia-utils-440
This won't install any X11 packages at all. Replace 440 with the driver version you want. nvidia-utils gives you nvidia-smi which is a CLI tool to show GPU utilization and temperature and other such information.
If nvidia-smi returns an error, check /lib/modprobe.d/blacklist-nvidia.conf and comment out the line alias nvidia off. Then you can enable the driver with sudo modprobe nvidia.
Zanna
  • 72,312
11
This worked for me (on Ubuntu 16.04):
sudo apt-get install nvidia-cuda-toolkit lightdm-
lightdm is the windows manager that nvidia-* installs. The dash at the end tells apt-get to uninstall the package but dependency resolution figures out not to install it in the first place. This still installed xserver-common (so you still get some X11 stuff) but it did not enable graphical booting. (Adding xserver-common- resulted in broken dependencies.)
PS. You're probably past this problem but this answer is for future internet generations.
Zanna
  • 72,312
sudo apt-get -s install --no-install-recommends nvidia-current seem to be rather sparse with the dependencies on my box, but it already has a full graphical environment.
What you could in theory do is:
  1. Let apt-get download the pkg without install: sudo apt-get -d install nvidia-current
  2. Pick up the desired deb from the cache: ls /var/cache/apt/archives/ | grep nvidia-
  3. Install using dpkg, ignoring relevant dependencies: dpkg -i --ignore-depends=package1,package2 package3.deb
Dependencies are of course there for a reason, if I where in your situation I'd just let apt do its thing. Some X11-software won't hurt you much unless you run it.
azzid
  • 876
If running (say, Blender on a headless server, you don't need all those dependencies.
Download the CUDA drivers from as a runfile from: https://developer.nvidia.com/cuda-downloads
Run sudo sh cuda_8.0.44_linux.run (or newer version)
Download the NVIDIA drivers from http://www.nvidia.com/Download/index.aspx?lang=en-us
Run: sudo sh /backup/iso/NVIDIA-Linux-x86_64-367.44.run (or newer version)
Note: Every time you update to a newer kernel, you'll have to reload the driver for that kernel. So you may want to add the "-a" (accept license terms) flag after going through them once.
My setup:
  • headless Xubuntu 16.04
  • dual GeForce 970 cards
  • Blender 2.78
Enjoy!
OpenPrivacy
  • 81
