While trying to update ubuntu I am facing this problem, don't much idea how to address this?
E: dpkg was interrupted, you must manually run 'sudo dpkg --configure -a' to correct the problem.
root@server1:/home/pawan# sudo dpkg --configure -a
dpkg: dependency problems prevent configuration of libssl-dev:
libssl-dev depends on libssl1.0.0 (= 1.0.1-4ubuntu5.38); however:
Version of libssl1.0.0 on system is 1.0.1-4ubuntu5.36.
dpkg: error processing libssl-dev (--configure):
dependency problems - leaving unconfigured
libssl-dev
As per the answer I ran the command but faced with this problem.
pawan@server1:~$ sudo apt-get install libssl1.0.0 openssl
[sudo] password for pawan:
Reading package lists... Done
Building dependency tree
libssl1.0.0 is already the newest version.
The following packages will be upgraded:
openssl
1 upgraded, 0 newly installed, 0 to remove and 31 not upgraded.
1 not fully installed or removed.
Need to get 0 B/524 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue [Y/n]? y
E: Internal Error, No file name for libssl1.0.0
pawan@server1:~$ sudo apt -f install libssl-dev
sudo: apt: command not found
pawan@server1:~$ sudo apt-get -f install libssl-dev
libssl-dev is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 32 not upgraded.
pawan@server1:~$
