I know that on many Desktop Environments, Using win + Space one can switch between installed language inputs.
Is there a command line way of achieving the same ?
Don't worry, there is a quick solution.
Open a new terminal and execute localectl set-locale LOCALEVAR=LOCALE to impose a new locale.
Before executing the command, replace "LOCALE" with the desired locale from the output of localectl list-locales and "LOCALEVAR" with any variable name from the output of locale.
If you want to change the keyboard input locale of the terminal use localectl set-keymap LANGNAME; if you want to change the keyboard input locale of the GUI use localectl set-x11-keymap LANGNAME. Replace "LANGNAME" with the short-name of your language.
Explanation: the console command localectl is used to change the system locale and keyboard layout settings.
The system locale if for the system services and the GUI; the keyboard settings control the keyboard layout used on the console and of the GUI.
Trying to help by posting an own answer using the setxkbmap command.
To switch to English(US):
setxkbmap -layout us
To switch to Kannada:
setxkbmap -layout in -variant kan
