My Asus just stopped might be the battery, but now it wont boot ubuntu,not sure how i got here but after alot of scrolling text I got the following message,
Error reading block 27263921 (attempt to read block from filesystem resulted in short read) while getting next inode rom scan.
/dev/sda2: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
        (i.e., without -a or -p options)
fsck exited with status code 4
The root filesystem on /dev/sda2 requires a manual fsck
I would be grateful of any help, what do i write?
Anwar
  • 77,855
Your system is already telling you exactly what to do:
/dev/sda2: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY. (i.e., without -a or -p options) fsck exited with status code 4
Go get your Ubuntu Live USB and boot into it. From there:
  1. Open a terminal (Ctrl+Alt+T)
  2. Run sudo blkid | grep ext and try to find your drive. It should return one line, containing an ID like /dev/sdb2 (replace this with whatever you got).
  3. Using the ID you got in step 2, run sudo fsck /dev/sdb2. If it returns any errors, you can run sudo fsck /dev/sdb2 -a to actially fix your filesystem.
Kaz Wolfe
  • 34,680
