When I attempted to copy a file (of size, ) over the network using scp I get a error <file> stalled
Why does this happen? How do I resolve it?
- 2,888
This happens because scp is trying to grab as much bandwidth as possible, and any delay (by a firewall, etc.) can stall it. Limiting the bandwidth (with -l option) will fix it.
For example, you might want to limit the bandwidth to 1 MB/s (= 8192 Kbits/s):
scp -l 8192 <file> <destination>
- 207,228
I've managed to solve it by using rsync:
rsync -avz -e "ssh -o StrictHostKeyChecking=no -o UserKnownHostsFile=/dev/null" --progress /tmp/bigfile.txt user@host.com:/tmp/
- 201
Any chance you're behind a Cisco ASA firewall? If so, turn off "sequence number randomization" and that'll help a lot -- also disable TCP Offload (ethtool -K $INTERFACE tso off gso off gro off) if you're on a Cisco ASA with Broadcom NICs in your server.
- 121
Given the error message that we received when the scp stalled I suspected that it was the encryption that was failing. "The authenticity of host 'myserver (10.10.11.12)' can't be established. ECDSA key fingerprint is SHA256:+zkyskXlxVQ0kRorLW26pzprIYbsM4N3hbaDLz1RNpo" With that in mind I ran "scp -c aes128-ctr /tmp/test.dan/bigfile.src myserver:/tmp/bigfile". scp WAS successful with the alternate cipher. Is there an issue with the default cipher blowing a buffer space?
Might try adding "-c " with an alternate cipher and see if it resolves your stall.
- 11
