I recently dual booted Ubuntu 16.04 with Windows 10, and I'm new to Linux.  I have a lenovo Ideapad 500, 16 gb RAM, AMD FX 8800.
After I installed Ubuntu the wifi wasn't working and I found a solution where you had to install the driver in a new directory (I think it was this).
So my wifi is working now, but the problem is that the connection is slower than it is in Windows 10, the download speeds are slower and I confirmed with speedtest.net (In windows I get4-7 Mbps and in Ubuntu I'm getting ~0.5 Mbps). I tried a solution where you had to add a nohwcrypt command to a driver file (I think), and this solution. But it doesn't work, the internet is still slow.
This is the output of sudo lshw -C network:
  *-network
   description: Ethernet interface
   product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
   vendor: Realtek Semiconductor Co., Ltd.
   physical id: 0
   bus info: pci@0000:01:00.0
   logical name: enp1s0
   version: 15
   serial: 1c:39:47:39:23:cb
   capacity: 1Gbit/s
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
   configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168h-2_0.0.2 02/26/15 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
   resources: irq:228 ioport:3000(size=256) memory:f0404000-f0404fff memory:f0400000-f0403fff
*-network
   description: Wireless interface
   product: QCA6164 802.11ac Wireless Network Adapter
   vendor: Qualcomm Atheros
   physical id: 0
   bus info: pci@0000:02:00.0
   logical name: wlp2s0
   version: 20
   serial: c8:ff:28:55:b3:0b
   width: 64 bits
   clock: 33MHz
   capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
   configuration: broadcast=yes driver=ath10k_pci driverversion=4.4.0-36-generic firmware=SW_RM.1.1.1-00157-QCARMSWPZ-1 ip=192.168.1.70 latency=0 link=yes multicast=yes wireless=IEEE 802.11abgn
   resources: irq:235 memory:f0000000-f01fffff
And this is the outpot of iwconfig:
lo        no wireless extensions.
enp1s0    no wireless extensions.
wlp2s0    IEEE 802.11abgn  ESSID:"INFINITUMlrfv"
      Mode:Managed  Frequency:2.417 GHz  Access Point: 0C:96:BF:A9:48:F4
      Bit Rate=1 Mb/s   Tx-Power=20 dBm
      Retry short limit:7   RTS thr:off   Fragment thr:off
      Power Management:on
      Link Quality=50/70  Signal level=-60 dBm
      Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
      Tx excessive retries:196  Invalid misc:8   Missed beacon:0
