I am running Ubuntu 14.05. Every time I reboot after a 2-3 days or a week, the Nvidia driver is disabled because of the automatic software updates. Is it possible to configure the automatic software updater to NOT disable the Nvidia driver? Thank you.
Asked
Active
Viewed 1,938 times
When you get a new kernel in an update, the nvidia driver needs to be rebuilt for the new module. You need to fix your build environment, something is missing. List the nvidia packages you have with
dpkg -l |grep nvidia
and then for the driver, (nvidia-361 in the below example) get the packages it depends upon:
apt-cache depends nvidia-361
The output looks like:
nvidia-361
Depends: x11-common
Depends: make
make-guile
Depends: sed
sed:i386
Depends: dkms
Depends: linux-libc-dev
Depends: libc6-dev
Depends: patch
patch:i386
Depends: acpid
Depends: lib32gcc1
Depends: libc6-i386
Depends: passwd
passwd:i386
Depends: adduser
Depends: libc6
Depends: <libgl1>
libgl1-mesa-glx
Depends: libx11-6
Depends: libxext6
...snip
install the missing ones and the kernel updates should not longer break things.
When you run an older kernel, is Nvidia still broken? What driver are you running when not running Nvidia? (nouveau?) If nouveau, check for the line "blacklist nouveau" in any file in /etc/modprobe.d
ubfan1
- 19,049
