I need to install Linux, better Ubuntu, to my 4 GB flash-drive. As 4 GB is too small for normal desktop version of Ubuntu I have downloaded alternate version through here because of recomendation from here. But there are few problems with installation. Almost at the start of the process it shows up first error:
Some of your hardware needs non-free firmware files to operate.  The firmware can be loaded from
removable media, such as a USB stick or floppy.
The missing firmware files are: iwlwifi-7260-9.ucode iwlwifi-7260-8.ucode
If you have such media available now, insert it, and continue.
Load missing firmware from removable media?
After which was second error:
The missing firmware files are: rtl_nic/rtl8411-3.fw
I have found some useful information about this on the internet, but thats all I found. In that topic author uses debian and debian commands, so I can't use it personally. But I have downloaded firmware-iwlwifi_0.43_all.deb and can not unpack it.
Any ideas how to fix this?
Laptop: Dell Vosto 5470.
Telion
  • 133
First run dmesg in the terminal to get diagnostic data as follows.
┌──(rootkali)-[~]
└─# dmesg
Then you will get missing firmware failed to load  highlighted in red as
[   13.491010] iwlwifi 0000:01:00.0: firmware: failed to load iwl-debug-yoyo.bin (-2)
[   13.491013] firmware_class: See https://wiki.debian.org/Firmware for information about missing firmware
Copy the firmware info after failed to load (iwl-debug-yoyo.bin) in this case.
Then enter this command followed by the missing firmware you copied from above like this:
┌──(rootkali)-[~]
└─# apt-cache search iwl-debug-yoyo.bin
firmware-nonfree-contrib..............90393jklflsdk
Then you get this. Finally, install that firmware by running this command/
┌──(rootkali)-[~]
└─# apt install firmware-misc-nonfree........-090-9-0sdlf
Don't forget to replace firmware-misc-nonfree with what you obtained by following the procedure.
karel
  • 122,292
  • 133
  • 301
  • 332
The iwlwifi firmware pertains to your wireless card. Go here:
http://www.intel.com/content/www/us/en/support/network-and-i-o/wireless-networking/000005511.html
And download the correct 7260 driver. Unzip the .ucode files and put them on a usb. You can also skip the error and later put the .ucode files into /lib/firmware.
The second error pertains to your Ethernet port. You can also skip that error, download the drivers here:
https://packages.debian.org/jessie/firmware-realtek
and place the correct .fw files within the /lib/firmware folder.
Also, which version are you installing? 16.04 should have full support for the 2 previous devices.
--upvote if this helped :)--
negusp
  • 2,831
The package linux-firmware contains the file: /lib/firmware/iwlwifi-7260-9.ucode
If you have ethernet setup, then do:
sudo apt-get install linux-firmware
If not download the deb file. Make sure that you choose the correct distribution version.
Then,
sudo dpkg -i *.deb
BTW Debian commands do work in Ubuntu.
Gayan Weerakutti
  • 3,830
  • 28
  • 39
