The program Terminology works perfectly only in guest session. Normal user or root experience following error:
ERR<9467>:terminology main.c:3001 elm_main() Could not initialize key bindings. ERR<9467>:efreet_cache lib/efreet/efreet_cache.c:1108 on_send_register() org.enlightenment.DBus.Canceled Canceled by user. CRI: lib/eet/eet_lib.c:626 eet_shutdown() eina_log_print() unknown domain -1, original message format 'Init count not greater than 0 in shutdown.'
syslog:
failed to rescan: Failed to parse /usr/share/applications/terminology.desktop file: cannot process file of type application/x-desktop
As-WARNING **: failed to rescan: Failed to parse /usr/share/applications/bamf-2.index file: cannot process file of type text/plain
Gs-WARNING **: failed to get updates: no results to show
find $HOME -name "*terminology*"
- shows empty config folder
terminology.desktop file looks for me ok: http://pasteall.org/81724
All non-guest users cannot open terminology as well.
The problem persists after purging and reinstalling emulator.
Searching for the answer I stumble upon the guest user session: why unity is able to use an application library in such a different way from unity in regular user session ? To make it understandable, maybe leads to further solution? Does it make sense for you? What is the background of these issue and how to solve it?
