122
CMake Error at CMakeLists.txt:1 (cmake_minimum_required):
  CMake 3.6.0 or higher is required.  You are running version 3.5.1
-- Configuring incomplete, errors occurred!
I know Ubuntu uses stable releases that it can support, but some repos require later versions of cmake. I want to overwrite the old cmake with the later version of cmake, but the common PPA doesn't carry the cmake I need. How can I upgrade cmake to use the needed version without conflicts with the older version?
Wolf
  • 3,247
Warning -- Do not do step 2 if you have Robot Operating System (ROS) installed
  1. Check your current version with:
    cmake --version
  2. Uninstall it with:
    sudo apt remove cmake
  3. Visit https://cmake.org/download/ and download the latest bash script.
    • In my case cmake-3.6.2-Linux-x86_64.sh is sufficient.
  4. Copy the script to /opt/.
  5. Make the script executable:
    chmod +x /opt/cmake-3.*your_version*.sh
  6. Change to desired installation directory (to /opt/ for example)
    • As of cmake 3.10.2 the installer no longer seems to install to /opt by default
  7. Run:
    sudo bash /opt/cmake-3.*your_version*.sh
    You will need to press y twice.
  8. The script installs the binary to /opt/cmake-3.*your_version* so in order to get the cmake command, make a symbolic link:
    sudo ln -s /opt/cmake-3.*your_version*/bin/* /usr/local/bin
  9. Test your results with:
    cmake --version
ignacio
  • 195
Wolf
  • 3,247
64
In the new version of cmake (ex: 3.9.6), to install, download tar file from https://cmake.org/download/. Extract the downloaded tar file and then:
cd $CMAKE_DOWNLOAD_PATH
./configure
make
sudo make install
avazula
  • 165
ptphucbk
  • 741
I would like to follow your advice Wolf, but the script don't install the prog. So i just creat the folder but doesn't show like installed when i do
 cmake --version
I find a other way peraps more easy :
sudo -E add-apt-repository -y ppa:george-edison55/cmake-3.x
sudo -E apt-get update
sudo apt-get install cmake
