I a question like this has been asked before, but none of the solutions I found have worked, and I think my problem is different, because it's more like Steam not detecting the library. Exact error message:
You are missing the following 32-bit libraries, and Steam may not run: libc.so.6
When I try run sudo apt-get install libc6:i386, it returns this:
Reading package lists... Done
Building dependency tree
libc6:i386 is already the newest version (2.23-0ubuntu3).
You might want to run 'apt-get -f install' to correct these:
gcc-5-multilib : Depends: libc6-dev-i386 (>= 2.11) but it is not going to be installed
libc6-dev-x32 : Depends: libc6-dev-i386 (= 2.23-0ubuntu3) but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
I have tried apt-get -f install, which returns this error:
dpkg: error processing archive /var/cache/apt/archives/libc6-dev-i386_2.23-0ubuntu3_amd64.deb (--unpack):
trying to overwrite '/usr/include/bits', which is also in package libc6-dev-amd64:i386 2.23-0ubuntu3
It looks like my problem is that the file is there, but for some reason it is not detected by Steam.
