I got ubuntu 16.04 for my computer but without many of the drivers was useless so i went to ubuntu 14.04, now i have to move to windows 7 because of some studies that require windows, problem is if i try to install it with the USB linux blocks me, any can help me please?
In order to install Windows 7, you need to download a copy from Microsoft's website. You will also need to purchase a product key. After this you need to create an install image (on a USB drive, or a CD) this should be possible through Ubuntu's startup disk creator utility. If you reboot into your BIOS, you select the drive, and it should guide you through the installation process.
It may not be possible to create Windows installation media from Ubuntu 14.04, but I have been able to from 16.04. In order to do this, you may need to borrow a Windows PC or a Mac from a friend.
This process will undoubtedly take some troubleshooting and patience (not to mention money for a license key). My suggestion if you are simply trying to run some windows software is to avoid the hassle of setting up a dual-boot system entirely. I recommend that you use a virtual machine, which can be a temporary or permanent solution, and completely free. A good option is generally Virtualbox, (Available in Ubuntu Software Center) it is available across-platforms and is free software. It is also possible to download a free version of Windows 7 from Microsoft that will work well with Virtualbox, or other Virtual Machine Software.
Best of Luck!
