I tried to install anaconda on my Ubuntu VM (following this), but for some reason the installation skipped on adding anaconda to the PATH variable. I followed instructions here and it somewhat helped. Now I have to call:
export PATH=$PATH:/home/myname/anaconda3/bin
every time. It works (for example, if I want to import numpy) , but obviously not comfortable. how can I solve it so it will work from now?
this is the PATH variable -
PATH="$HOME/bin:$PATH:/home/name/anaconda3/bin"
and echo $PATH returns /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
when I try to import I get -
    >>> import numpy
Traceback (most recent call last):
  File "<stdin>", line 1, in <module>
ImportError: No module named 'numpy'
right now, calling echo $PATH in the in the window where i called source gives
/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:/home/ofirarzi/anaconda3/bin:/home/ofirarzi/anaconda3/bin
but in any other window I get
proton
  • 147
There are 2 possible solutions:
1. Correct the $PATH statement manually:
You have made an error in your ~/.profile file which accounts for anaconda not being in your $PATH. Your have added here:
# set PATH so it includes user's private bin if it exists
if [ -d "$HOME/bin" ] ; then
    PATH="$HOME/bin:$PATH:/home/ofirarzi/anaconda3/bin" <-------
fi
which is incorrect as the conditional statement tests for the directory $HOME/bin and if this is not present the extra $PATH will be ignored. In your case I suspect you do not have a $HOME/bin...
Try the following instead (leaving preceding lines of ~/.profile untouched):
    PATH="$HOME/bin:$PATH"
fi
export PATH=/home/ofirarzi/anaconda3/bin:$PATH
Note that the new anaconda $PATH is prepended rather than appended as explained in this post. Then test by running the following two commands:
source ~/.profile
echo $PATH
And now all should be well, if not:
2. Allow the installer to correct the $PATH:
If there is still some trouble I note that the anaconda installer offers to make the required changes for you. I installed on Xenial and saw the following offer at the end of installation (the arrows are my addition):
creating default environment...
installation finished.
Do you wish the installer to prepend the Anaconda2 install location
to PATH in your /home/andrew/.bashrc ? [yes|no]    <-----
[no] >>> yes                                       <-----
Prepending PATH=/home/andrew/anaconda2/bin to PATH in /home/andrew/.bashrc
A backup will be made to: /home/andrew/.bashrc-anaconda2.bak
For this change to become active, you have to open a new terminal.
Thank you for installing Anaconda2!
Share your notebooks and packages on Anaconda Cloud!
Sign up for free: https://anaconda.org
andrew@athens:~$
And on my Xenial system typing 'yes' added the following to ~/.bashrc:
# added by Anaconda2 4.1.1 installer
export PATH="/home/andrew/anaconda2/bin:$PATH"
So a re-installation of anaconda is another option, allowing the installer to do the hard work :)
andrew.46
  • 39,359
I follow those steps and works for me!
Installing Anaconda #
At the time of writing this article, the latest stable version of Anaconda is version 2020.02. Before downloading the installer script, visit the Downloads page and check if there is a new version of Anaconda for Python 3 available for download.
Complete the following steps to install Anaconda on Ubuntu 20.04:
1- Anaconda Navigator is a QT-based GUI. If you are installing Anaconda on a desktop machine and you want to use the GUI application, install the following packages. Otherwise, skip this step.
$sudo apt install libgl1-mesa-glx libegl1-mesa libxrandr2 libxrandr2 libxss1 libxcursor1 libxcomposite1 libasound2 libxi6 libxtst6
2- Download the Anaconda installation script with your web browser or get :
$wget -P /tmp https://repo.anaconda.com/archive/Anaconda3-2020.02-Linux-x86_64.sh
The download may take some time depending on your connection speed.
3- This step is optional, but it is recommended to verify the data integrity of the script.
Use the sha256sum command to display the script checksum:
$sha256sum /tmp/Anaconda3-2020.02-Linux-x86_64.sh
The output should look like this:
2b9f088b2022edb474915d9f69a803d6449d5fdb4c303041f60ac4aefcc208bb  /tmp/Anaconda3-2020.02-Linux-x86_64.sh
Run the script to start the installation process:
$bash /tmp/Anaconda3-2020.02-Linux-x86_64.sh
You should see an output like the following:
Welcome to Anaconda3 2020.02
In order to continue the installation process, please review the license agreement. Please, press ENTER to continue
Press ENTER to continue. To scroll through the license, use the ENTER key. Once you’re done reviewing the license, you’ll be asked to approve the license terms:
Do you approve the license terms? [yes|no]
Type yes to accept the license, and you’ll be prompted to choose the installation location:
Anaconda3 will now be installed into this location:
/home/linuxize/anaconda3
- Press ENTER to confirm the location
- Press CTRL-C to abort the installation
- Or specify a different location below
The default location should be fine for most users. Press ENTER to confirm the location.
The installation may take some time, and once completed, the script will ask you whether you want to run conda init. Type yes.
Installation finished.
Do you wish the installer to initialize Anaconda3 by running conda init? [yes|no]
This will add the command-line tool conda to your system’s PATH .
To activate the Anaconda installation, you can either close and re-open your shell or load the new PATH environment variable into the current shell session by typing:
$source ~/.bashrc
To verify the installation type conda in your terminal.
That’s it! You have successfully installed Anaconda on your Ubuntu machine, and you can start using it.
Updating Anaconda # Updating the Anaconda is a pretty straight forward process. Open your terminal and enter:
conda update --all
for more information and more clear explanation go to the source link below
Resurse
Kasem777
  • 111
Just reinstall again and on the last question "do you want to add the path" answer yes. You must've answered no.
Merry
