I have dual boot Linux + Windows 8. Today I've tried updating to windows 10 and after a while got error on boot:
error no such partition
entering rescue mode
grub rescue>
Listing all the drives using ls, gives "unknown filesystem" on every one. (So I cannot set prefix/boot.)
I have booted with liveUSB opened gparted and noticed that /dev/sda4 which used to be linux, became unallocated.
I have tried boot-repair, did not helped. I have tried putting windows8 usb and choose ~"fix boot option", did not help too.
Ideas are much appreciated. Thank you.
EDIT: GParted image
This is how my drive looks like, somehow after windows upgrade /dev/sda4 became "extended". I know that this is where linux files are.
At very worst I just want to get my files from Linux back. I'm trying to use TestDisk, but when trying to view files in that partition it gives me "Can't open filesystem. Filesystem seems damaged." Any ideas how can I recover files?
EDIT2:
Thanks for suggestion oldFred. I'm trying to use parted to restore files/partition. This is what parted print gives me:
Number  Start       End         Size        Type      File system  Flags
 1      2048s       1026047s    1024000s    primary   ntfs         boot
 2      1026048s    488631857s  487605810s  primary   ntfs
 3      488632320s  489639935s  1007616s    primary   ntfs         diag
 4      489644030s  976771071s  487127042s  extended               lba
 5      911235072s  976771071s  65536000s   logical   ntfs
EDIT FINAL: I was able to find missing partition using "parted" and following oldFred posts. Thank you everyone for the help. Problem solved!
Wagm
  • 103
Windows deleted your LInux partition but it still is there and just needs to be re-added to partition table. You can use testdisk or parted rescue.
Some then work, others need grub or fsck but most are able to recover missing partition. Of course you do have good backups just in case of issues?
Windows 10 upgrade led to grub rescue
Use parted rescue to restore missing partition details in post #22
http://ubuntuforums.org/showthread.php?t=1775331 http://www.gnu.org/software/parted/manual/html_node/rescue.html http://gparted.sourceforge.net/faq.php/#faq-22
Parted rescue seems easier than testdisk
'Upgraded' to Windows 10 on dual boot, and can't boot to Ubuntu partition
oldfred
  • 12,583
I had faced this problem once before and don't worry this solution below will get rid of your problems away for sure.
  1. Download and install spotmau boot suit 2012 to another computer
  2. Get at least 4 GB USB Drive
  3. Run spotmau boot suit and make your USB Drive Bootable by its ISO file.
  4. Plug the USB to your laptop and press F12 to boot from USB liveboot
  5. You will see temporary environment of windows. Open Boot suit icon on Desktop and click on startup recovery at the left side tab
  6. Scan for boot mgr and copy bootmgr or try replace it.
  7. Restart the computer, and should work
Good luck.
1- Download and install spotmau boot suit 2012 to another computer 2- get at least 4 GB USB Drive 3- run spotmau boot suit and make your USB Drive Bootable by its ISO file. 3. Plug the USB to your laptop and press F12 to boot from USB liveboot 4. You will see temporary environment of windows. Open Boot suit icon on Desktop and click on startup recovery at the left side tab 5. Scan for boot mgr and copy bootmgr or try replace it. 6. Restart the computer, and should work
Good luck.
You can't see your partition because it converted to GPT. The easiest thing to do is, on your temporary environment click start and type 'diskmgmt.msc'. The you should see your hard disk labeled as gpt or ext4. Format that labeled partition to NTFS file type and do the former steps 3 to 5 again. hope it'll work.
