I tried to install zRam using following commands in terminal -
sudo add-apt-repository ppa:shnatsel/zram
sudo apt-get update
sudo apt-get install zramswap-enabler
But it throws the following error which says that the package is not available,
E: Couldn't find package zramswap-enabler
I could not even find any repository with name shnatsel/zram or similar in my system.
As an alternative, i tried to install it from its deb file, which throws dependency error even though i have kernel 2.6.38-13-generic installed in my system.
Dependency Error:
Error: Dependency is not satisfiable: linux (>= 2.6.37.1)|linux-image (>= 2.6.37.1)|linux-generic (>= 2.6.37.1)|linux-image-generic (>= 2.6.37.1)|linux-image-generic-pae (>= 2.6.37.1)|linux-server (>= 2.6.37.1)|linux-virtual (>= 2.6.37.1)|linux-image-server (>= 2.6.37.1)|linux-image-virtual (>= 2.6.37.1)
Is there any way to fix it ?
user24665
  • 183
That ppa is for Ubuntu 11.04 / 11.10 (as you can see when you click on technical details).
That is also the reason for your dependency error when you try to install the .deb manually.
For Ubuntu 11.10+ versions, this is available in the official repositories as: zram-config. You just need to run $ sudo apt install zram-config to install it.
Yozachar
  • 180
  • 13
imbaer
  • 2,911
For older versions: below are the exact steps as mentioned on its official Launchpad page.
On older (pre 9.10) Ubuntu systems
Step 1: Visit the PPA's overview page in Launchpad. Look for the heading that reads Adding this PPA to your system and click the Technical details about this PPA link.
Step 2: Use the Display sources.list entries drop-down box to select the version of Ubuntu you're using.
Step 3: You'll see that the text-box directly below reads something like this:
deb http://ppa.launchpad.net/gwibber-daily/ppa/ubuntu jaunty main deb-src http://ppa.launchpad.net/gwibber-daily/ppa/ubuntu jaunty main
Copy those lines.
Step 4: Open a terminal and type:
sudo gedit /etc/apt/sources.list
This will open a text editor containing the list of archives that your system is currently using. Scroll to the bottom of the file and paste the lines you copied in the step above.
Save the file and exit the text editor.
Step 5: Back on the PPA's overview page, look for the Signing key heading. You'll see something like:
1024R/72D340A3 (What is this?)
Copy the portion after the slash but not including the help link; e.g. just 72D340A3.
Step 6: Now you need to add that key to your system so Ubuntu can verify the packages from the PPA. In your terminal, enter:
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys 72D340A3
Replace 72D340A3 with whatever you copied in the step 5.
This will now pull down the PPA's key and add it to your system.
Step 7: Now, as a one-off, you should tell your system to pull down the latest list of software from each archive it knows about, including the PPA you just added:
sudo apt-get update
Now you're ready to start installing software from the PPA!
rrj
  • 411
