I have Lubuntu 11.10 installed on /dev/sda3, and Xubuntu 11.10 on /dev/sda5. A while ago, while being on Lubuntu, I made a mistake somewhere in creating a Live USB: by mistake, I installed a Live USB bootloader into /dev/sda3. This didn't result in any problem at that time.
Today, I updated the kernel. I had to restart Lubuntu. In Grub, Lubuntu suddenly didn't appear anymore, and I booted automatically in Xubuntu. I tried to run update-grub and tried to use grub-customizer to get Lubuntu back in Grub, but this didn't work. I ran os-prober, but it doesn't show me Lubuntu.
Then, I tried to add a new entry to /etc/grub.d/ on /dev/sda5 called 12_lubuntu. It contained the following:
#!/bin/sh -e
echo "Lubuntu"
cat << EOF
menuentry "Lubuntu" {
set root=(hd0,3)
linux /boot/vmlinuz
initrd /boot/initrd.img
EOF
After doing that, I ran update-grub and with grub-customizer, I wrote the Grub-configuration to MBR, that is: /dev/sda.
Suddenly, Lubuntu appeared in Grub. I tried to launch it, but when doing this, the following messages appeared:
Error: File not found
Error: You need to load the kernel first
The output of ls -all in /dev/sda3 is as follows:
gijs@Gijs-PC:/media/9c715f68-f083-46ab-9d55-6139556f31d4$ ls -all
totaal 112
drwxr-xr-x  23 root root  4096 2011-11-25 23:35 .
drwxr-xr-x   5 root root  4096 2011-11-26 10:55 ..
drwxr-xr-x   2 root root  4096 2011-11-22 22:17 bin
drwxr-xr-x   4 root root  4096 2011-11-25 23:36 boot
drwxr-xr-x   2 root root  4096 2011-10-15 21:58 cdrom
drwxr-xr-x   5 root root  4096 2011-10-12 18:08 dev
drwxr-xr-x 146 root root 12288 2011-11-25 23:37 etc
drwxr-xr-x   3 root root  4096 2011-10-15 21:59 home
lrwxrwxrwx   1 root root    37 2011-11-25 23:35 initrd.img -> /boot/initrd.img-3.0.0-14-generic-pae
lrwxrwxrwx   1 root root    33 2011-11-25 23:35 initrd.img.old -> /boot/initrd.img-3.0.0-14-generic
drwxr-xr-x  19 root root  4096 2011-11-22 22:17 lib
drwx------   2 root root 16384 2011-10-15 21:56 lost+found
drwxr-xr-x   5 root root  4096 2011-11-24 20:59 media
drwxr-xr-x   2 root root  4096 2011-10-09 09:29 mnt
drwxr-xr-x   4 root root  4096 2011-11-24 17:15 opt
drwxr-xr-x   2 root root  4096 2011-10-09 09:29 proc
drwx------  13 root root  4096 2011-11-22 17:19 root
drwxr-xr-x   5 root root  4096 2011-10-15 22:01 run
drwxr-xr-x   2 root root  4096 2011-11-22 22:17 sbin
drwxr-xr-x   2 root root  4096 2011-06-21 20:43 selinux
drwxr-xr-x   2 root root  4096 2011-10-12 18:06 srv
drwxr-xr-x   2 root root  4096 2011-07-14 07:11 sys
drwxrwxrwt   8 root root  4096 2011-11-25 23:37 tmp
drwxr-xr-x  10 root root  4096 2011-10-12 18:06 usr
drwxr-xr-x  13 root root  4096 2011-11-25 23:37 var
lrwxrwxrwx   1 root root    33 2011-11-25 23:35 vmlinuz -> boot/vmlinuz-3.0.0-14-generic-pae
lrwxrwxrwx   1 root root    29 2011-11-25 23:35 vmlinuz.old -> boot/vmlinuz-3.0.0-14-generic
I've also found the old 30_os-prober_proxy in /dev/sda3/etc/grub.d, which should contain the old boot stuff. It is as follows:
#!/bin/sh
#THIS IS A GRUB PROXY SCRIPT
'/etc/grub.d/proxifiedScripts/os-prober' | /etc/grub.d/bin/grubcfg_proxy "-*
-'Ubuntu, met Linux 3.0.0-12-generic-pae (on /dev/sda3)'
-'Ubuntu, met Linux 3.0.0-12-generic-pae (herstelmodus) (on /dev/sda3)'
+'Ubuntu, met Linux 3.0.0-12-generic (on /dev/sda3)' as 'Xubuntu'
-'Ubuntu, met Linux 3.0.0-12-generic (herstelmodus) (on /dev/sda3)'
+'Windows 7 (loader) (on /dev/sda2)' as 'Windows 7'
How can I make Grub start Lubuntu again?
Boot-Repair
The majority of grub boot issues can be resolved through using boot-repair - as this community wiki explains, you can install this on a liveCD/USB or directly in a working ubuntu install and it will attempt to find all O/S installs and repair the overall Grub MBR.
Manual Grub2 Installation
If boot-repair fails to work its magic then the traditional manual grub2 installation method described in this community wiki should be investigated.
Search on that web-page for the section Copy LiveCD Files. Replace the example /dev/sdxy statements with the partition that you have installed lubuntu in - for example /dev/sda3
If you are unsure which partition you have installed then you can run the Boot-info-script found on SourceForge.
In the results look for partitions types of ext4 or ext3 - these are the common Ubuntu filesystems unless you previously elected to use something like btrfs or reiserfs etc.
Kernel reinstallation
If the issue is a corrupt kernel installation then you can investigate reinstalling the kernel from a live CD. This is described in this excellent AskUbuntu Q&A
By installing the kernel correctly, Grub should be able to see the Lubuntu installation correctly.
fossfreedom
  • 174,526
Remove the second line (the one starting with echo). You might also have to add a root-parameter to the kernel, like this:
linux /boot/vmlinuz root=/dev/sda3
After that run update-grub again.
bseibold
  • 1,513
You can try using a live cd to boot into the system and then chrooting to the lubuntu system using these commands.
sudo mkdir /mnt/abc
sudo mount /dev/sda3 /mnt/abc
sudo mount ‐‐bind /dev /mnt/abc/dev
sudo mount ‐‐bind /proc /mnt/abc/proc
sudo mount ‐‐bind /sys /mnt/abc/sys
sudo chroot /mnt/abc
sudo grub-install /dev/sda
I think this would fix your problem, if you don't want to have lubuntu loader in the MBR you can install grub in /dev/sda3 and then use update-grub using xubuntu. That would work.
gaurav
  • 113
A week ago, I've had the same problem another time, but now I fixed it myself. It turned out that the problem had nothing to do with the LiveUSB-install. What I had to do, was start grub-customizer from Xubuntu, click File, Select Partition, click Next, select Lubuntu's partition, and then click Mount the selected filesystem. I had the option to select submountpoints, but that wasn't necessary. I clicked Apply.
Right now, I had to check all the checkboxes that were available to be sure that I could start Lubuntu from Grub. Then I clicked File, Save, after that, I clicked File, Install to MBR.
I rebooted, and I could boot into Lubuntu again, the problem was solved.
If this doesn't solve your problem, I'd advice you to use the tools that fossfreedom mentions in another answer below.
