After upgrading my install from 14.04 to 16.04 on a notebook which has Nvidia GT 740M, I want to change GPU driver from Software & Updates > Additional Drivers. System identifies my graphic card, no problem but when I select a proprietary driver and apply changes after a few seconds, change bar stops and nouveau selected by default again.
I ran this command:
sudo apt-get install nvidia-370
but output says you have held broken packages
Reading package lists... Done
Building dependency tree
nvidia-370 : Depends: lib32gcc1 but it is not going to be installed
I also tried:
sudo apt-get install lib32gcc1
But it says:
lib32gcc1 : Depends: gcc-6-base (= 6.0.1-0ubuntu1)
I've tried using main server, but that didn't solve my problem. I also tried to fix broken packages with the following commands:
sudo dpkg --configure -a
sudo apt-get purge
sudo apt-get clean
Results of running: apt policy lib32stdc++6 gcc-6-base lib32gcc1
lib32stdc++6:
Instalados: (ninguno)
Candidato: 5.4.0-6ubuntu1~16.04.2
Tabla de versión:
5.4.0-6ubuntu1~16.04.2 500
500 http://archive.ubuntu.com/ubuntu xenial-updates/main amd64 Packages
500 http://archive.ubuntu.com/ubuntu xenial-security/main amd64 Packages
5.3.1-14ubuntu2 500
500 http://archive.ubuntu.com/ubuntu xenial/main amd64 Packages
gcc-6-base:
Instalados: 6.2.0-3ubuntu11~14.04
Candidato: 6.2.0-3ubuntu11~14.04
Tabla de versión:
*** 6.2.0-3ubuntu11~14.04 100
100 /var/lib/dpkg/status
6.0.1-0ubuntu1 500
lib32gcc1:
Candidato: 1:6.0.1-0ubuntu1
Tabla de versión:
1:6.0.1-0ubuntu1 500
It seems that gcc-6-base refers to 14.04 still.
