I installed an application called Wireshark, using:
sudo apt-get install wireshark
I searched it and launched it. Then, I tried to uninstall it using GUI. But it is not removing.
I tried using:
sudo apt-get remove wireshark
And the weird thing is that the application is still in the system!
Cristiana Nicolae
  • 4,570
  • 32
  • 46
5 Answers5
10
The following procedure should wipe wireshark from your system: First uninstall the wireshark package and all related configuration files:
sudo apt-get remove --purge wireshark
Then remove all dependencies that are no longer needed:
sudo apt-get autoremove
biber
  • 311
I wanted to simply make a comment, but seems like I have to make an answer. The method is shown here: https://www.youtube.com/watch?v=WOJWbAyjflk
sudo apt-get remove --autoremove wireshark wireshark-*
sudo rm -rf /etc/wireshark
check if everything is removed with whereis wireshark
Jecke
  • 121
I used the following commands to remove wireshark because i had the similar problem
sudo -i
apt-get purge wireshark-*
apt autoremove
Then i checked if everything is removed using
whereis wireshark
It is directory(without the packages) was still there at /etc/ so i removed it using
rm -rf etc/wireshark
I wanted to reinstall the Wireshark to restore the default config I unintentionally changed. To do so after doing what Rithik Gandhi says, remove the config folder located in ~/.config/wireshark.
I removed it by typing "sudo apt-get autoremove" in terminal, and then going to Ubuntu Software and search for wireshark and then uninstall. It worked for me.
Hokkis
