I am running Ubuntu GNOME 16.04.1 with GNOME 3.20 (though I was running 15.10 when I installed it) and when I installed NetBeans 8.1 I selected to install Tomcat and GlassFish as well which seem to be located in /usr/local as far as I can tell along with NetBeans. NetBeans also seems to be quite interconnected with them so I would probably have to do at least part of the uninstallation through NetBeans or would have to do quite a lot of tweaking to cleanly remove them.
But as I don't have a real use for them and security updates keep being released for Tomcat, but even though there is a bugzilla report open on this matter, they haven't backported in a Tomcat update in ages so I am rather worried on the security front.
So is there any way to uninstall Tomcat and GlashFish? I have checked and it did not install the packages from the repositories.
In order to uninstall these components you will need go into the directories in which they are installed in /usr/local (or wherever you install NetBeans to, if sudo is not used during the installation then it is likely to be ~) and execute the uninstall.sh files:
sudo uninstall.sh
This should launch the NetBeans installer which you should select the Uninstall option on. This will completely remove the components you run the uninstall.sh files for.
