I have run: sudo apt-get build-dep monodevelop but it returned:
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
 builddeps:monodevelop : Depends: libmono-cecil-cil-dev but it is not going to be installed
Josh Pinto
  • 8,089
Please reference this post to give you some context to my answer.
Run $ sudo apt-get install libmono-cecil-cil-dev.
I don't know why this is necessary, but manually installing the problematic package should get your install of monodevelop to work.
It is possible that after installing the unmet dependency libmono-cecil-cil-dev, other unmet dependencies might pop up, but repeating the process with the new unmet dependencies should finally get you to the point of being able to install monodevelop.
