14
So, I mounted Kali Linux Light iso image on my usb stick and ran it Live. Eveything was fine. When I finished, I shut down the Kali and unplugged my usb. Then I turned back on my PC and my screen started flashing before login screen.
I'm getting this message:
/dev/sda1: recovering journal
/dev/sda1: clean 221608/30269440 files, 4431756/121048320 blocks
[  OK  ] Starting Anonymizing overlay network for TCP.
[  OK  ] Created slice User Slice for gdm.
         Starting User Manager for UID 121...
[  OK  ] Started Session c1 of user gdm.
[  OK  ] Started User Manager for UID 121.
         Stopping User Manager for UID 121...
_
I'm not sure if this is connected somehow.
I tried this (but it didn't help):
  1. Checked BIOS settings
  2. Reinstalled GRUB using my installation USB (I ran a live version with it, here's the report - http://paste2.org/78CUHf9H )
  3. Scanned for issues in recovery mode
I can hit CTRL+ALT+F1 while my screen is flashing, but every 4 seconds my monitor flashes again with this error message ^^ so I need to hit those buttons again to access the terminal again, it's really annoying.
Zanna
  • 72,312
ramseyy
  • 346
I would normally refer you to my Q&A on NVIDIA issues, but that involves using TTYs, which won't work for you, at least right away.
Boot into Recovery Mode, drop to a root shell, and follow the steps below:
  1. Run mount -o rw,remount / to mount the drive in Read-Write mode.
  2. Run sudo apt-get purge nvidia-* to purge the NVIDIA driver.
    • You may also need to purge xserver-xorg and reinstall it, which will require you to enable networking in Recovery.
  3. Reboot. You may have to add the nouveau.modeset=0 flag in GRUB to boot properly (Check my Q&A for specifics).
You should be past the screen flicker and be at your desktop.
  1. Now reinstall the NVIDIA drivers the proper way:
    • sudo apt-get install nvidia-367 (or 340, 352, 364, 370, whichever works).
  2. Reboot again.
You should be up and running: good as before. I don't see how Kali could have done this, but if you messed around with your filesystem, then it's definitely possible.
TheWanderer
  • 19,525
  • 52
  • 65
I had the same problem. When examining the logs in /var/log it was kindof obvious, that the issue was because of gdm3. Since lighdm never works for me I had to find a completely different display manager. It worked for me with SLiM, bit i did not try any other dm yet. I'm probably just going to install some flat theme for it and keep it.
https://wiki.ubuntuusers.de/Displaymanager/
sudo apt-get install slim
i managed to get into tty2 (Strg+Alt+F2) and do this. But if this doesn't work for you, you can also enter a console in the advanced boot options on startup.
https://wiki.ubuntu.com/RecoveryMode
(Nvidia & Ubuntu 16.10)
sezanzeb
  • 308
I had the same problem, SLiM did not help at all, so I reverted everything like this:
  1. Boot from live CD
  2. Mount my Harddisk with chroot as described here under Update Failure: https://help.ubuntu.com/community/LiveCdRecovery including writing the resolv.conf entry
  3. Navigated to my Downloads folder where the Nvidia driver was and did an uninstall with: cuda-repo-ubuntu1604-9-0-local_9.0.176-1_amd64.deb --uninstall
  4. Deleted /etc/modprobe.d/blacklist-nouveau.conf and regenerate kernel: sudo update-initramfs -u
  5. Edit grub to boot into text console
  6. Reboot into harddrive
  7. login to command line
  8. sudo apt-get install nvidia
  9. reboot
  10. Finally back in the graphical system, took the whole night, hope this helps someone doing the same s**t.
linuxmarc
  • 119
