I am using Ubuntu 14.04.3 LTS, when I try to run command hostnamectl I get error:
bash: hostnamectl: command not found
Which library shall I install to use hostnamectl ?
hostnamectl is provided by systemd-services package in Ubuntu 14.04. You need to install that package to get the command line utility
sudo apt-get install systemd-services
To find out which package a file is you can use apt- file:
sudo apt-get install apt-file
apt-file update
After using it it is as simple as :
ricardo@zeus:~$ apt-file search hostnamectl
cdist: /usr/lib/python3/dist-packages/cdist/conf/type/__hostname/explorer/has_hostnamectl
systemd: /usr/bin/hostnamectl
systemd: /usr/share/bash-completion/completions/hostnamectl
systemd: /usr/share/man/man1/hostnamectl.1.gz
systemd: /usr/share/zsh/vendor-completions/_hostnamectl
Once apt -file package tells you that the file is found , you just have to install it:
