15
Attempting bash arithemetic for a script, but $e does not update till the end. The output speaks for itself.
max=5
for e in $(seq 1 1 $max); do
    percent=$(( $e/$max*100 ))
    echo "echo $e / $max : = $percent"
done
Tl;DR: Display 1..5 as a percentage.
Output :
echo 1 / 5 : = 0
echo 2 / 5 : = 0
echo 3 / 5 : = 0
echo 4 / 5 : = 0
echo 5 / 5 : = 100
Why is this?
Eliah Kagan
  • 119,640
CybeX
  • 526
bash cannot handle non-integer arithmetic. It will give you the correct result as long as all the expressions are integers. So you need to avoid getting a non-integer value somewhere in your calculation.
In your case, when you are evaluating 1 / 5, 2 / 5 etc. it creates the integer zero values in bash correspondings to some non-integer values and the results are coming out to be zero accordingly. Precedence of division and multiplication are the same and same precedent operators are always executed left to right as they are placed in the expression.
One work around will be to do the multiplication first and then the division so bash never has to handle non-integer value. The corrected expression will be,
$ max=5; for e in $(seq 1 1 $max); do percent=$(( $e*100/$max )); echo "echo $e / $max : = $percent"; done
echo 1 / 5 : = 20
echo 2 / 5 : = 40
echo 3 / 5 : = 60
echo 4 / 5 : = 80
echo 5 / 5 : = 100
sourav c.
  • 46,120
16
Bash doesn't do very well at this kind of arithmetic... Here's your problem:
$ echo $((1/5))
$ echo $((2/5))
$ echo $((4/5))
$ echo $((4/5))
If you need to handle non-integer values, you can use bc
$ max=5; for e in $(seq 1 1 "$max"); do percent=$(bc <<< "scale=1 ; $e/$max*100") ; echo "echo $e / $max : = ${percent%.*}"; done
echo 1 / 5 : = 20
echo 2 / 5 : = 40
echo 3 / 5 : = 60
echo 4 / 5 : = 80
echo 5 / 5 : = 100
(thanks to @Arronical for pointing out how to format the output as integers)
Zanna
  • 72,312
11
Unlike bash, awk offers full floating point arithmetic. For example:
$ awk -v max=5 'BEGIN{for (e=1;e<=max;e++) print "echo " e " / " max " : = " 100*e/max}'
echo 1 / 5 : = 20
echo 2 / 5 : = 40
echo 3 / 5 : = 60
echo 4 / 5 : = 80
echo 5 / 5 : = 100
John1024
  • 13,947
Try
See section ARITHMETIC EVALUATION of:
man bash
It only supports integer.
snoop
  • 4,110
  • 41
  • 58
alfred
  • 603
