When I run:
sudo apt-get install libcurl4-openssl-dev
I get the error:
Reading package lists... Done
Building dependency tree
 libcurl4-openssl-dev : Depends: libcurl3 (= 7.35.0-1ubuntu2) but 7.35.0-1ubuntu2.8 is to be installed
                        Depends: libkrb5-dev but it is not going to be installed
                        Depends: librtmp-dev but it is not going to be installed
If I then try and install each of those dependencies manually, it gives me a similar error for another dependence of the dependency...dependency hell, which I thought apt-get was created to avoid.
Why isn't it installing the dependencies automatically?
I'm running Ubuntu 14.04.
Cerin
  • 6,923
When I run sudo apt-get install libcurl4-openssl-dev I get the following:
$ sudo apt-get install libcurl4-openssl-dev
The following extra packages will be installed:
  libcurl3
Suggested packages:
  libcurl4-doc libcurl3-dbg libidn11-dev libkrb5-dev libldap2-dev librtmp-dev
  libssh2-1-dev libssl-dev pkg-config zlib1g-dev
The following NEW packages will be installed:
 libcurl3 libcurl4-openssl-dev
0 upgraded, 2 newly installed, 0 to remove and 1 not upgraded.
Need to get 639 kB of archives.
After this operation, 1,745 kB of additional disk space will be used.
Do you want to continue? [Y/n]
I suspect your "broken packages" may be your problem. I would run sudo apt-get autoremove and sudo apt-get install -f to see if you have anything held up. then run your install again.
